Features:
- support for complex nodes architecture (MIMO systems, multiple
radio/antenna interface support)
- support for energy consumption simulation
- support for nodes birth and death
- support for physical sensor and physical measures input / output
- support for physical phenomenon / measures
- support for interactions between nodes and physical phenomenon /
measures
- support for omniscient monitoring entities
- support for complex antenna radiation patterns
- support for MIMO systems
- support for modulation functions
- support for various propagation models
- support for propagation delays
- support for various interference models
- support for multiple radio resources (FDMA, CDMA)
- computation of bit-error-rate and packet-error-rate as a function
of the signal to interference ratio and the modulation
- eventual introduction of errors in packets as a function of the
computed ber
- tunable radio medium simulation: independent sinr and ber values
may be computed for each byte of a packet or may be averaged over
slices of the packet
